220 rings
Wormi
220 rings
Postby Wormi » Mon Apr 03, 2017 5:29 pm
I got some overhauled jugs for my 220 and trying to get some rings and pistons. I was told to be carefull when buying rings. Was told not to buy the e series rings because they will eat up the cylinder walls. Anybody have more info on this. Trying to do this one time. Thanks.
twister69z
Re: 220 rings
Postby twister69z » Tue Apr 04, 2017 5:20 pm
Duccarra is the best place to get rings.
Otherwise known as DG Supply.
Twister69z
Wormi
Re: 220 rings
Postby Wormi » Tue Apr 04, 2017 9:31 pm
Got the rings from ducarra but can't find the pistons. They need to be .015 over. Anybody have them. Tried outlaw aircraft but can't seem to get nobody on the phone. The rings look like they are beveled a little so which side is the top. They don't have any #'s stamped on them. Any help on this would be greatly appreciated.
406 JAMIE
Re: 220 rings
Postby 406 JAMIE » Wed Apr 05, 2017 10:14 am
try JD or CECIL here in west melbourne fla they mite have what u need.good luck hope this helps. :rebel:
brouss2785
Re: 220 rings
Postby brouss2785 » Thu Apr 06, 2017 1:10 am
I have 12 .15 pistons
brouss2785
Re: 220 rings
Postby brouss2785 » Thu Apr 06, 2017 1:11 am
.015
Wormi
Re: 220 rings
Postby Wormi » Thu Apr 06, 2017 6:32 pm
Brouss, pm sent
john westerman
Re: 220 rings
Postby john westerman » Tue Apr 11, 2017 12:58 pm
Duarra rings bevel goes up do not mix #1&2 UP IF YOU LOOKTHE RINGS ARE DIFFERENT COLORS
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 5 guests
