7x12 sled "Gangster Boats"
trailerdon
Post by trailerdon »
Picked up a sled, kind of a fixer upper. never herd of this hull.
Any feedback on this hull would be helpful
gangster sled 027.jpg (18.91 KiB) Viewed 7251 times
SwampNinja
Post by SwampNinja »
It would help with a couple pics sir. Thanks.
I am here: http://tapatalk.com/map.php?ee5axj
"It is what it is."
trailerdon
Re: 7x12 sled "Gangster Boats"
fresh pic's. or not, tells me file is too large. Thanks anyway
SwampNinja
Can't see pics apparently. Have to minimize them.
"It is what it is."
StrokiN&SmokiN
Post by StrokiN&SmokiN »
trailerdon wrote:Picked up a sled, kind of a fixer upper. never herd of this hull.
Hey I live in punta gorda I can maybe check it out or text me a pic 305-216-7793 or email floridacracker178@yahoo.com
:florida:
2.5 ton buggy under construction
13.6x7.6 calusa,450hp 383 stroker,2.68 rotator,80" 3blade "R" sensenich
trailerdon
I have got the top deck off, going to need one sheet for sure "2024 .063" . pulling the poly next, "it is horrible". Then I can
get a good look at the bottom.
not sure how I got this pic to come up, but if I figure it out I'll post more
SwampNinja
Snap pics of everything. I'm curious to see what this looks like.
I am here: http://tapatalk.com/map.php?5e2h14
"It is what it is."
Post by John Fenner »
if you have any type of picture software on your computer, right click on pic and click on open with to find the one that allows you to resize them,crop them etc. then save as,,,,, I put the ones I use on SA in a separate folder.
trailerdon
Finally got a pic up !
CONTINENTAL CRACKER
Post by CONTINENTAL CRACKER »
You got any other pics of it in different angles of the hull?
I WOULD RATHER PADDLE A CANOE THAN OWN A WATERPUMPER
StrokiN&SmokiN
Looks like a thurman hull. Hopefully the bottom isn't to bad. What u putting on it? :florida:
trailerdon
Took me 5 days to figure out how to get a pic up ! I'll try for some differant angles tomarrow. As for power, I,ve got alot of time to think about that. However more is better
yobee
Post by yobee »
Looks like a franny taylor
woodwagon
Post by woodwagon »
I just bought a very similar hull only 10x6'8. Hopefully ur bottoms in better shape than mine. Im going to try a fasco product to smooth out the dents and bellies. Ive been trying to post pics for 2 weeks as well with no luck. Good luck on the build
When in doubt, throttle out!
SwampNinja
Lol... Woodwagon let me know if you need help posting pics.
It looks like a Taylor hull to me as well.
I am here: http://tapatalk.com/map.php?xnbggg
"It is what it is."
floridacrakr0470
Post by floridacrakr0470 »
if im not mistaken, that hull used to belong to a freind of mine here in mims. gangster airboats was the nickname of the group that used to ride together,not the mfg of the hull. they used to have those stickers on a couple different hulls. i was wondering if it was his old hull when i saw the title of the thread.
StrokiN&SmokiN
Taylor hulls weren't flat across the back they kinda bow down in the middle of the transome and thurman hulls kinda bow up then down in the front of boat the way that one does. kinda like a hancock and scorpion but not so skinny on the sides.
Last edited by StrokiN&SmokiN on Mon May 21, 2012 3:30 pm, edited 1 time in total.
I dont think Franny would have dropped the nose that hard, looks more like a Thurman hull due to the taper of the hull, what say you Mike? If it is a Taylor hull it will have double rivets in the bow cap support rails in the front. Also the center gusset t-bar rivets arent staggered and are side by side.
SWAMPCRACKER85
Post by SWAMPCRACKER85 »
Could be an older Cloniger or Davis.
10'6x7 cut down Ricochet, 0-300 Clunkinental 68x34 Sensenich kevlar tip narrow
StrokiN&SmokiN
Definitely not cloninger or Davis that I can say. I'm pretty sure its a thurman..
MUGSHOT
Post by MUGSHOT »
Whatever it is! Looks like a great sled to get her off and running. Good luck with the project, she has nice lines and deserves to have someone build her right.
2014 Derek Eaker sled with a IO540 5 Blade Saber....
Built By D@E Metal works in Homestead Fl. (786) 412-9018
12x7 7075T6 .125 Bottom Full Deck....
Maintained by Airboat Gus (786)236-8216
Proud member of the Airboat Association Of Florida (AAOF)
Mike Thurman
Post by Mike Thurman »
After careful inspection I think we can claim it... Just looking at the transome, rivit layout, side rail, the rounded camber of the sides of the boat/transome. And the triple louvers on the hatch cover went on every boat. The older boats had on facing forward and one facing back, the later ones both faced back.. Every Taylor I have ever seen was built with angle at the bottom of the transome making the transome completly flat. We use T-Bar for the transome . It keeps the transome from getting ripped out. Does it have dual tanks?? or storage box's under the side decks??? Fuel tank hole looks about right too.. I cant really tell, but which way are the side rail rivit's facing?? are they shot from the inside and bucked on the outside??? I'd like to see a picture of the top of the deck with the hatch covers removed, Also a picture of the underside of the covers and the latches used on them.. Then I could be certin..
Airboat Headquarters Inc.
Sensenich Propeller Dealer
Bud Marquis Supporter
JUNIOR480
Post by JUNIOR480 »
when i first seen it mike ...i thought it was one of yours to...
just has the thurman (LOOK).if ya no what i meen...
if if aint,when they built it they had one of yours in there shop...lol
HAULIN A$$ SINCE 78......
trailerdon
that is a good bit of info. Single gas tank 13x9x33, my math puts it at 19 gal. aircraft latches on center hatch. I will be sure to get some more pic's. I now have the front and rear top deck off , I'll get some interior pic's that will show the construction layout. No storage boxes on side decks
S A airboat file 030.JPG (61.5 KiB) Viewed 6820 times
S A airboat file 028.JPG (59.44 KiB) Viewed 6819 times
S A airboat file 032 (2).jpg (70.55 KiB) Viewed 6813 times
Mike Thurman
Plus we put the "crown" in the front deck. That boat has that "tell tale" look.. The deck is not flat across from side to side. It's higher in the center. Nobody else ever really put the work into them to crown the deck and drop the nose at the same time.
