TXSHOCKWAVE
Im looking at an older 1980's panther 15ft aluminum hull with polymer. The boat has a 540 with and wooden prop currently and wont run dry very well at all. If i was to buy the boat and replace the prop with a 70-72" composite will it make a real difference in the push? I have seen a 16ft older panther with a 540 run dry just fine with a composite 2 blade.
