i have a 0-290 that i have been running for a few years i recently put new pistons,rings,main and rod bearings pretty much a total overhaul the problem is too much oil pressure on a cold crank i have 100psi at idle after heating up it gets right with about 30psi idle and a good climb with acceleration.i have checked the check vale spring and ball i did not have this problem before so im confused the engine is oiling because i ran it hard too seat the the rings and even took a ride around the yard unless i have something hooked up rong on my acessory case with oil pressure gauge and oil cooler lines help would be greatly apprieciated thanks...kmr...
