0470 identifying
I have an 0470 and I am trying to find out which one it is. Has a homemade intake on it. Has 2 mags that are on top of motor not off the back, and aircraft starter that comes off the side of the case. Only tag I have found says 81178-1-L-4 I am attaching pictures. Thank you for any help and god bless
It started its life as a fuel injected model. The last digit will be a letter. For instance IO-470-k. The parts are almost al interchangeable. Continentals early model 470s started with a letter IE. E-185. Then they made some that ended in a number, IE. IO-470-13. Yours is one of the "newer model" 470s.
