Alaska viking
Active member
Well, I made the switch. Pulled the servo, spider, injectors, and pump.
Installed a new MA 4-5 carb, plugged the injector holes, and just got the new low pressure pump, (mechanical), from Jernigans.
What's the trick for getting the pump arm all the way in? Research says there is a steel rod that dropped down upon removal of the old pump, and needs to be held up in order to get the new pump all the way in.
Any tricks/advice?
Any tricks/advice?
