CULTURED REDNECK
MY TRIM TAB DECIDED TO OPERATE IN ONLY ONE DIRECTION THIS WEEKEND, DOWN... WHAT A DRAG, HUH? I THOUGHT IT WAS THE SWITCH, SO I REMOVED IT AND WHEN I BY PASSED THE SWITCH, THE MOTOR OPERATED JUST FINE. I CLEANED THE TERMINALS WITH A WIRE BRUSH, REINSTALLED THE SWITCH AND I WAS BACK IN BUSINESS. THE NEXT DAY, SAME STUFF HAPPENED AGAIN, BUT THIS TIME THE OLD BYPASS THE SWITCH ROUTINE DID NOT WORK. I EVEN CUT THE WIRE SIX INCHES FROM THE MOTOR AND PUT CURRENT TO IT. THE "DOWN" WIRE MADE AN ARC, BUT THE "UP" WIRE DID NOT ARC AT ALL, NOTHING, NADA, ZILCH... MABEY A GROUND PROBLEM, MABEY JUST JAMBED?? ANY SUGGESTIONS WOULD BE APPRECIATED!!!
