Have'nt posted in a while but been reading. I still haven't done anything different to the 180. Still does most everything I want it to do but it won't run dry. Went on a bad ass bowffishing trip a couple of weeks ago and shot 5 big buffalo and 7 huge flounder. My only chance to get this thing to run dry seems to be to pull a cylinder and check the pistons, to see if by some small chance they are the low compression ones. If they are, it's a $500 for parts fix. Don't know what the labor would be. And that's used parts. If I read it right, the low comp 180's are 168 HP. Would that last 12 HP make this thing move on the dry????? And the bolts from the cylinders to the case, where do you get a wrench to fit them? They look like a big allen head with not much room around them. Seems like I could check the piston on one cylinder myself if I had the right wrench. IS IT THAT COMPLICATED or is it a matter of torquing it back down right. I'd hate to get into it and put it out of commission right in hunting season.
