hey guys i am going to start the build up of my motor in a few days i would like to know if theres anything special that needs to be done to the lower end.
so far this is what i am doing (budget is tight hull and rigging got expensive for me)
stock lower end with new rings and bearing with a slight hone to the cyl,s
i was thinking to stock specs on the gaps and clearences ?
i have the stock heads or some fresh marine heads (will get casting #s)
summit cam kit sum-k1100,double roller timing
and the general new rebuild stuff.
any suggestions or comments would be appreciated
