digginfool
I'm in the unique position of being owed a gearbox from one of the manufacturers (doesn't matter who; at least for now). After I sent that gearbox in for repair, I bought another brand in 2.55 (same ratio). After several years, that gearbox failed and because at that particular time I was in dire need of my boat, I bought a second gearbox to use while what would become my backup was being rebuilt. ASSUMING I ever get my original gearbox back (a story I've been sitting on for going on 4 years), I'm contemplating having it sent back as a 2.68. I've always wondered how my boat would perform with the higher ratio. It's a 15' DB with a well worked over LSA (fully forged rotating assembly, LS9 cam, springs and 10% overdrive pulley for the supercharger; theoretically is capable of 675 hp but realistically around 600) turning a 4 blade 81.5" NGR. Currently, pitched at the 3 mark (which is around 19 degrees of pitch), I'm spinning it at 5,600 RPM. I know the NGR likes RPM but I've also been told it likes pitch as well. With the 2.68, the prop would spin only 100 RPM less but there would be more torque. Is it worth the experiment? I certainly don't need three gearboxes in 2.55 but this does provide an opportunity to check it all out.
