Des Moines Boater
I have the PE-150, 220 GPU and I want to change the cylinders to the O-470. Do I need different push rod tubes and push rods, different valve covers, piston wrist pins? I heard the O-470's will bolt right on, but I need to know what else I need to convert to the dual mag system.
Also the mags are suppose to be the Bendix S6LN-23. Can I use the Bendix S6LN-25 or is there a Slick mag with impulse I could use?
