220 gpu parts
ranger
I recently asked about plug wires,well I've changed all the plug wires to 7mm solid core. Did not make a difference at all. So i pulled all the cylinders found i have 1 bad intake valve ,1 bad exhaust valve and there was little to no compression. plus it smoked pretty bad. So does any body have cylinders, rings,& pistons. I could probably use my existing cylinders but I think they have been bored 15 over. Also has anybody had problems seating the rings on a gpu.
ranger, I don't know where you are located but if you take your boat to Tom Jeffords he can put the new chrome cylinders on and check out your wiring, magneto and timing and get you in good shape. I'll bet he can do the work for less than you could buy just the parts for. He has the parts and the experience. He lives in Lake Wales. I had low compression on two of my 220 GPU cylinders and got two new ones from him. It took 10 hours to notice the rings begining to seat and were well set after 20 hours. I have more than 30 hours on them now and couldn't be happier. His work is top notch, high quality.
I live In ocala,fl. I could'nt even tell you were lake wales is located.but I will look him up. Thanks for the advice
