A
Anonymous
Guest
Hey All:
Does anyone have any recommendations on what spark plugs to use in a 220 GPU (PE-150) engine? I've been using Champion D16s, but they seem to foul prematurely, and D21s, but they cause pre-ignition. I thought I had hit the right plug when I went to Autolite ??? (I can't remember the number), but they fouled after about 6 hours.
My setup is:
PE-150, made in '59, overhauled in '79, approx 200 hours since O/H
Original Zenith carb
Original Bendix magneto w/Hi-performance solid-core ignition cable
70x28 wide-blade wooden prop (F-Prop)
12x7 (Laser-like) fiberglass hull
Boat runs strong (like up the hill, down the levee, through the dirt parking lot strong), and we get about 46.5 mph (GPS speed) @ 2750 rpm, but it's becoming a nuisance having to change the plugs every third or fourth trip.
Or maybe I should just invest in a spark plug cleaner?
Thanks
Doc
My setup is:
Thanks
Doc
