c chardt
the 383 stroker is a torque motor it uses the same 350 block just has a longer stroke if you want a awsome engine talk to waterthunder and get one of his ls1 engines that will take 2or3 hundred pounds of the back of the boat also what is the ratio of your box and what prop are you running thunder can make any boat preform if you have the $$$$$$$$$$$$$
