Very good points. Another thing I've learned about stationary testing I seriously doubt the prop they claimed made the best thrust really did in any sense that was relevant to anyone other than those guys with that engine and gearbox on that boat on that day..That prop just complimented that engine/gearbox combo more
This is the most common question I get. "What prop makes the most thrust?" And the answer is All of them! Yeah I know...I don't know what I'm talkin about. Gimme a infinitely adjustable redrive system to set engine RPM where it needs to be, on damn near any adjustable-pitch prop and I'll get peak thrust so close you'll call me a liar. If a prop makes it’s peak thrust at 3000RPM and requires 300HP to maintain it there, I don’t care if it’s an DD A/C engine making 525#s of TQ at 3000 or a 2:1 redrive engine making ~290#s (Using a 10% loss factor) of TQ at 6000. As long as the engine is “allowed” to operate where it needs to be, and the pitch is set properly the engine’s HP will dictate the thrust, more than the prop choice. Everyone with me here?
For those that aren’t….Thrust tells me more about the POWER than the prop! I consider my thrust tester a prop dyno from the engine's perspective. It records infinite data about prop performance, and excellent data to make real-world decisions about setup and combination based on the curve of both the prop and engine. But the one black and white thing it does do, is show me if my engine/gearbox combo has the balls or not in a true measurement/calculation. And I ain't talkin about “I swing a so and so prop on #2 200 more RPM than you, so I must be makin more power” crap. That in itself is 10 times more flawed than trailer testing, but I ain’t up to that much typin tonight! LOL
It's having to make concessions based on only so many ratios available, and a fixed pitch that makes it a science within itself.
Two perfect examples are Dave’s engines and mine. My job is to move big boats with the biggest amount of reliable power and props available for a boat that can take it...I need peak thrust and to be able to build the engine that can handle that. Dave needs to build all-around packages on smaller boats that perform above and beyond in their arena. He needs smaller diameter props and more critical blade designs to optimize a more sensitive torque curve and boat. So yeah….It’s pretty simple when you think about it. LOL
Yeah...Long thread...Been drinkin, so don't correct me for typos or jibberish.
Felber
