Trying to get the carb on my 470 conversion dialed in. It has a two barrel Holley. #88 jets and a I believe a 4.5 power valve.
Seems to run pretty good, I'm happy with how it runs. But seems like in my research everyone seems to be running smaller jets then this, and I think im burning more gass then I should.
Stbd bank top. Left is rear. Threads are a bit oily on the rear. Dry on the others.
Port bank top. Right is rear. Same thing just the rear has oily threads.
Ngk ab-6. We put quite a bit of hours on it this weekend, between light load frogging and higher load ridding.
How do these plugs look?
The port bank I had to replace the piston in the middle cylinder because it had a bad intake boot before it and ran lean. I should have done all 3 while I had it apart. I have a suspicion the rear cylinder also needs rings and it's leaking oil. But I might use one quart for a tank, 25-30 gallons.
