I hope this works. I was adjusting the idle return on one of my 500HP fuel injected motors. I wanted it to return to an idle quickly and smoothly reeving it up!
It took a bit of work but I wanted the motor to come back to a perfect idle from any RPM. This motor made good low torque on the dyno and I'm sure it will even be more fuel efficient then the carbed motor. It should hit pretty hard down low with a three blade! I'm thinking about throwing it on my ride boat just to play with for a while!
The ignition controller with the bad gas option is on the way to you. Just connect the purple wire to a switch going to ground! Your fuel injected motor is almost done also I expert to have it ready to ship mid next week!
