Catfiish, first you got the right idea there. That mount lowers the center of gravity big time. Being a 2 stroke it could care less which way is up, assuming it doesn't have float type carbs. Diaphram carbs dont care.
You can not create HP with a reduction drive. HP in is equal to HP out minus any friction/gear losses. However torque on the other hand can be moved from one place to another with a reduction drive, by letting the engine run at its design speed and then letting the prop run at its design speed. Yoiu get more out of each that way.
Read the threads on reduction drives on the forum there are excellent writeups about what is multiplied and what is not and how to calculate where what will be and how much there will be. Its all right here on Southern Airboat for the reading.
I like the low engine mount it has been proved on gyroplanes and ultralights over and over and is a proven concept. Especially in gyroplanes which generally are fighting a low c/g and high center of thrust. Thats another discussion though. In an adeal situation the center of gravity and center line of thrust and the centerline of drag would all be equal but thats not attainable in a boat or ultralight, its just theoretical. But its better to approach things with that goal in mind.
In an airboat the center line of thrust is not as important as getting the weight lower , that is not to say the centerline of thrust doesn't matter. In bigger boats with big HP it can make their nose dive into the water under hard acceleration. In a mini application the low weight has more effect than the center of thrust line. You can still trim the boats by adjusting the thrust line and weight after its mounted.
I like the idea you found as a begining point for experimentation.
Scotty :wink:
