I have a 509 BBC thats low on power i think, been the same since i have owned it. Its has edelbrock 6045 heads 110cc combustion chamber, 1.7 roller rockers, roller lifters, dont have a clue what cam but sure its factory crate motor one(taking out now), dont know compression ratio maybe around 9.7to1, has 180 psi on compression guage. Max rpm i would like to turn 5300. Anyways iam gonna try a new cam, call comp cams they recommend:
XM270HR grind
Rpm range: 1600 to 5400
Lobe separation 112*
Intake centerline 110*
Duration @ .050 218/224
Lift .510/.510
What i was kinda thinking: not sure of
291THR7 grind
RPM range: 2200 to 5900
Lobe separation 107*
Intake centerline 102*
Duration @ .50 235/249
Lift .557/.543
Any help is greatly appreciated.
XM270HR grind
Lift .510/.510
291THR7 grind
Lift .557/.543
