picked up parts from the machine shop last friday. woke up early saturday morning and my buddy hunter arrived at the house about 9:00.It being darn hot and weren't no signs of get any cooler we set in assemblin his engine in the kitchin .Now cheryl shes is pretty understandin when it comes the needs of my airtboatin habits , just can't use her sink as a parts washer ( been there, done that ,not real good for the mariage) any how all went well and we finaly got the old motor on the boat ,cam broke in and the prop on. so heres the specks
hull 16'8"x8' hartline (big a** boat)
500 cadillac direct drive bored .040 over makin it a 509
600 holley carb, eldebrock intake ( wished we would have had a stock one)76 cc heads ,stock rockers,kb pistons and hasting rings From Potter top ring gaped .035,stock rods ,crank turned .010,all machine work and balancing was preformed by S.O.B. racing engines out of Samsula, FL. Hunter bolted a 72" sensenich narrow 3 blade propeller set at the number 2 mark and reved it up to 3000 rpm and set the timin at 34 degres , air fuel ratio runin about 12.49 wot and 13.50 at 2000 motor seems like its gonna make it ,however i believe it wants a better carb after 2000 rpms the engine starts pullin the vaccum secondaries open makin the throttle real sensitive between 2000 and 3000 rpm. we'll put her in the water sadurday at crystal river and we'll see how she does.
What carb would be a good choice for this application?
