airboater67
IO-520 doesn’t run well at idle. (Sometimes) new facet fuel pump has pressure and injection pump makes pressure on its own when pump is off. Runs great on the gas just an idle and cold start problem. Hard to get it to stay running on cold start. This engine is straight out of a plane and sometimes it idles really nice. Just a little hesitation right off idle. I know nothing about this engine . Still learning. Is there something obvious that I should check? Both mags working rpm drops when I kill each one. . Haven’t checked timing or points as I said sometimes it runs perfect, so I had no reason to think it was off. Seems like a fuel issue . Any help appreciated. Haven’t checked unmetered fuel pressure but metered is 2 1/2 to 3 at idle. What should these pressures be?
