N noisemaker Well-known member Sep 9, 2020 #1 6.ols motor being direct drive is the prop gonna be left or right hand rotation
kwanjangnihm Moderator Sep 10, 2020 #3 Smuggler said: Left hand Click to expand... Smuggler is correct left hand! If you add a gearbox it becomes right hand. Don't forget with a DD engine to monitor thrust bearing wear and crankshaft end play! Swamp has a home-brew oil concoction that may help extend bearing/wear life! :salute:
