600HP 468 BBC for sale
Waterthunder
Any body interested Felber and I are building a 600plus HP pump gas 468BBC. This motor is all choice parts. STD STD cross drilled nitrided steel crank, Eagle 3D rods with the L19 rod bolt up grade, JE pistons, fully balanced rotating assembly, file fit rings, Custom airboat grind Comp Cams roller cam, lifters, Edelbrock Oval port aluminum heads with airboat porting and 5 angle valve job, roller rockers, our favorite BBC intake, 830 annular Holley carb, distributor, deep sump pan, Fluid dampener balancer, flywheel, stainless headers and a new 1000HP rotator 2.68 soft drive gearbox all for $10,500. Anybody interested please PM this motor will be built from the ground up for airboat use. This short block combination has proven to be extremely reliable in off shore boat racing.
