D.M.B.,do you also use a blow by hose on the rear of your engine?I can't see one in the picture.My engine has one under the alternator and one on the front of the engine.
My mag is on the left side,as you face the front of the engine.The rest I've seen are on the right.Is there some reason for this,or do you just stick them where you want them?
Is that a Predator carb.?
