I am interested in occasionally exploring saltwater creeks and marshes in north Florida. I will also spend time in freshwater. I live in Tallahassee. I need some advice. I’m suspecting I should go with poly on the bottom and stainless steel rigging. True? How about the engine, aircraft or auto? Any other tips or things to consider? Thanks.
Ken,
You can run the big bend area ("The Armpit of Florida") in just about anything, I have run the area in my narrow grass and ground 7x13' airboats, my 14' mud boat, my 16' Carolina Skiff, my Jon boats (14-22), 20' etc. etc... Generally speaking, every time I have run there (in any of the above, for different reasons) I always find my butt hole held a bit tight vs. other places I have been (afraid of running aground on rocks in a kicker, afraid of hitting a rock or wave sinking in an airboat). With the Airboat I keep my foot in the throttle at all times I'm not on bottom because I don't want to sink my stuff in 5 foot of salt water. Every time I have left to come home I made a stop at one of my inland haunts to soak the boat in fresh water and wash as much salt as possible out from between the hull and poly.
If I lived in your area my #1 goal would be a boat I am comfortable killing the motor in a heavy chop with land a mile away and water deep enough that I can't touch. My #2 goal would be a boat that runs awesome and lasts while meeting goal #1. My #3 goal would be a boat I am willing to leave submerged for a few days till I sort out a solution.
I would be running an 8' wide high side or deck over boat, chine style, 14' minimum length. It would be welded 5052 aluminum, 0.125" thick on the sides/transom and 0.188-0.25" thick bottom. It would have T bar stringers full length every foot and half-length stringers between.
My Armpit boat would have sand blasted, unpainted, welded aluminum tubing rigging, but that takes the right fabricator, Stainless will work. The boat would have plenty of coolers and the deck would be finished in a "Fish, mud and Oyster Gut's" theme because that's what it would look like anyway.
My Tally boat would definitely run poly, 3/8" minimum, but more likely a big heavy 1/2" thick black poly slab that laughs at oysters (rocks, not so much). Aluminum fasteners for the poly are a must to minimize corrosion. Rivets are a good option (and what I use), but for a go hard and mess things up boat I would use aluminum screws to make poly changes as easy as possible.
A lot of boats will work 1st hull I had was fiberglass and didn't last 3 years fishing the waccassasa area.
Last time I was in the area I had to run over a busted/sunk fiberglass boat just to keep going, had to run it over on the way back.
As for motor, there are plenty of options, I would choose based on what you are willing to sink in the salt water. The hull and rigging usually comes out fine from a good sinking. Any gear box will need a rebuild, but the case and gears should survive. But the motor will be toast. My Tally boat would run a geared LS, not likely to be the stroked and forged version I'm presently building, more likely a junkyard iron 6.0, possibly a $2k rebuild, with waterproof aftermarket control.
Finally, my Tally boat will have a butt load of fishing rod/scallop net holders and will slide on that snot slick mud no problem, just watch out for the random oyster beds and rocks. You gotta know where you go when you slide!
