I can't say I disagree with you j.d. I'm the same way. Numbers would not mean much by themselves. BUT... I AM curious about it. Reason being, our boat is about at the bottom of the heap as far as power, thrust,... floating
and so on. Improvements are going to be made.
Thrust is a real meaningful thing. it measures the motor & prop at the same time.
If there is some way a user can get accurate thrust measurements, every time I do an upgrade, I could test my thrust, and see how much it helped/hurt the persormance.... BESIDES what the seat of my pants tells me.
Because the seat of my pants measurement is motor, prop, and also the aerodynamic and hydrodynamic effects of the rigging and hull/trim tabs/etc.
Really, I could take it or leave it - Thrust numbers. Add more time/money is the way 99.999% of us do it. But if I do get them, they are worthless unless they are accurate, and
consistant from measurement to measurement. But they would be helpful during some trial & error style upgrading.
One thing for sure, they never will be a bragging point for me!!! I can't afford to buy one of those performance motor/prop combos.... MUCH LESS pay for maintaining it and replacing it when it dies young from running so hard.
I know I'd buy the service from the SAO member who I think may have started on this as a business venture. At least once or twice. And coming from the same guy, the numbers would be consistant (which is critical to using the numbers)... and they'd be consistant from boat to boat - which means the bragging rights will be valid too.
matt.
