Incognito90
First off, we’re new to the forum, glad to be here, and glad to finally own an airboat! I enjoy seeing all the support and input across this forum.
Over the last several months my brother and I have been rebuilding a 2012 20’ x 8' deep hull Pathmaker that we picked up. When we got it, it only had a single seat, cage, 454 BBC with 11 original hours, and motor stand. Guy had the hull built so that he and his son could rig it out together for bow fishing but unfortunately “life” happens and things get pushed to the back burner. Fortunately it wasn't due to any family illnesses. We’ve always wanted one, never owned one, but have been on them numerous times over the years. We were fortunate enough to have the resources to do just about everything ourselves from welding, layout, fitting, painting: cage, platform, seat boxes, and console are powder coated and hull, stand and fuel tank is liquid painted, and wiring, or had good friends in the line of work that we couldn’t do ourselves which saved us no telling how much money.
We have access to a 500 acre flooded river pasture so my brother took it out over the weekend to see how it handled after adding all of the extra weight. As I mentioned earlier, we have been on airboats numerous times but have never owned one, and are by no means experts on handling/operating them although we are pretty mechanically inclined and catch on pretty quick on operating stuff with, or without wheels haha... To my surprise, it handled great. It did not porpus, the bow did not plow/dig any, held true to the stick and didn’t try to walk or pull one way or the other when going straight, and did not feel top heavy when turning. I feel we could use a little more rpm but just have to play with it a little more this coming weekend. Our whirlwind stump pullers are currently set at 20 degrees, and saw 3800 max rpm on the trailer, 4000 max rpm on the water, and cruised around 3500ish from what my brother remembers and felt that it was performing pretty good. He ran it up dry in a small loop to ensure he could get back to water without getting stuck. He did make it, but could tell it wouldn’t just run dry as it is. I’m curious if less pitch and more rpm would help do the trick? I would like to drop them back to 17.5 or maybe even 15 degrees to try and get a little more rpm because from what whirlwind has said and what I’ve read, our props need to be spinning 2200-2700 max rpm. Is that correct?? I know we just need more stick time to really get a good feel for everything and just play with the pitches maybe. Fortunately, we have unlimited access to that River pasture to play and learn on with in fairly shallow to shallow water. We have had a blast building it, didn’t kill each other, (took a couple of deep breaths, but made it happen :slap: lol) Hope you guys enjoy the pics, and am open to any and all comments, questions, Concerns, or ideas. Thanks in advance!!
