Hi there
I was wondering if anyone can help me I'm from Northern Ireland I bought a hovercraft a couple of years ago to use to take me out duck hunting.It worked OK but I new that an airboat would be better with having nobody over here that knows anything about them I had a go at converting my hover craft.I got a flat bottom aluminium hull made and fixed that craft into it done away with the lift part of the craft so all the thrust is going out to drive it forward instead of a third of the air going into the Hull to lift it when it was a hovercraft.It had 8 fan blades as a hovercraft I removed 4 and have them pitched to optimum engine RPM which is 3500 my engine is a 31hp Briggs and stratton vanguard as a hovercraft with 2 people it would do 30_35mph I wouldn't be getting the half of that now I have a small video of it on an early test run maybe someone can give some help many thanks
