wow, that's a barge. if you are planning on making a tour boat, that;s the hull to have but if you are looking trail ride and hunt etc. you might wanna think about findin a 10-12' hull or so. my buddy has a pe90 on a 12' glades hull and it will flat out run.
guys on here know a ton more than me may reiterate this or maybe not, i think that 90 will not be nearly enough power, maybe even dangerously underpowered.
just for an example, laughman lodge has a boat that big but is powered by about at least 750 horsepower big block with two props and it still couldn't even look at dry ground. even with only an operator.
the motor is great tho. good luck with the project and make sure to keep it polymer side down!!! :lol:
