I'm down to the final wiring of the new 540.
I installed the gear driven aircraft alt that plugs into the front of the motor.
There is a plug @ the front of the alt that read " L - IG", which I know means "Light & Ignition".
I've seen some just attach an "ON/OFF" switch to the plug & manually turn it on & off.
I've also got the factory plug that has (2) two separate wires.
I'm thinking the best way is to attach the (2) two wires together & run them to the "ACC" tab in the ignition switch.
Any suggestions on what's right & wrong?
CJ
CJ
