nebraskaairboater
I have a guy in our airboat club looking to replace his oil cooler on a 4 cyl Lycoming Aircraft engine. Last year he had "high compression" pistons and rings put in it and now it runs hot when it is hot outside. What do you all use for oil coolers? It is a true "aircraft" engine with up-draft carb and dual mags. Any help appreciated in figuring size and source.
Thanks,
Dan
Thanks,
Dan
