Hi, i have a continental 0470 and use high octane unleaded pump gas mainly because that's what was used by the previously owner and av gas is over five dollars a gallon in my area. My boat seems to run very well. I am looking for comments on the pros & cons of the use of marvel mystery oil (mmo) in the fuel system. Sense I don't use leaded fuel which dissipate heat I am considering using mmo to help lubricate as well as reduce carbon buildup in the combustion chamber walls, valve guides, valve stems, and spark plugs. I have talked with a couple a/c engine builders and their comments were mmo was not a lead substitute but would not heart to use it either. has anybody ever used mmo in their a/c motor? thanks, ed
