dragonfly470
Has anybody had a clearance problem between their alternator pulley and a Stump Puller series prop on a 220 gpu engine application?
I'm trying to install a new Stump Puller series prop on my boat. My alternator mounts below the prop adaptor like most others I've seen. Because of the belt groove on the prop adaptor,the alternator must remain where it is. By time I get enough blade pitch to load the engine to my satisfaction, I WILL be in danger of rubbing the alt. pulley.
So I called Jim at Whirlwind and he told me I could swap at no charge for Super Snapper blades which have a different profile and will eliminate the problem.THANKS WHIRLWIND!.
So back to the original question. what is everybody doing for this application?? Thanks...Jim J
