SHEPHERD OF CHRIST
Would like some opinions some thoughts experience on alumitech Hulls thanking very seriously about getting one 15 x 8 I appreciate everyone who comments
My biggest problem is I can't decide on what size motor maybe that's a good problem to haveHave a 2021 14x8- but I had them customize it from their original design. I went with 20" sides, 18" transom, added 5 extra stringers, 2 Jack's, and a shimmed cross brace. 30" rake with a step. Strapped a 550 cubic inch big block with a 2.37 and 4 blade JX to it. I never looked back - to busy looking forward at all the bushes I plow over-
Alumitech builds an awesome unmatched hull. But if you want custom rigging, I'd advise you to buy their hull and take it somewhere to have the rigging and cage built.
My boats for sale right now because I have alumitech building me a 16ft hull for a new big block I'm having built.
Bigger family now- need a bigger boat.
I have my second Alumitech hull scheduled to be built. I ordered it sometime in March. My current hull is a 15'x7.5' modified AGI hull with a 540 BBC. It's built like a tank with extra T-bars and other bracing. We do things different in Louisiana. Jim fusses about it but accommodates me. Ask him about the longer tapered grass rake. He named it after me.Have a 2021 14x8- but I had them customize it from their original design. I went with 20" sides, 18" transom, added 5 extra stringers, 2 Jack's, and a shimmed cross brace. 30" rake with a step. Strapped a 550 cubic inch big block with a 2.37 and 4 blade JX to it. I never looked back - to busy looking forward at all the bushes I plow over-
Why? It seems silly to me to put a hopped up on steroids LS race motor into a boat that by description needs to be reliable and run on low grade fuel.Thoughts on a 490ls waterthunder for a motor this is going to be a search and rescue boat could have at least five to six people at times as well as pulling boats in
Well to tell the truth I thought about a big block just not sure what size I don't want to go Overkill but I want enough power I can pull another boat in if he happens to be stuck somewhereWhy? It seems silly to me to put a hopped up on steroids LS race motor into a boat that by description needs to be reliable and run on low grade fuel.
For the cost of 1 passenger a big block can do all you want and run on 87 all day. Add a E85 tune, add 93 tune, add a 93/nitrous tune, add a 110/nitrous tune, etc. etc., a big block can be versatile on an equally sized hull.
In my world 200 lbs or an extra passenger is big. For your described application a Big Block is the only choice worth considering, you get power with reliability. Hull size is where the optimizing should be done.
Yes I would use them or Prestige Motorsports in North CarolinaSmeding performance in Texas builds good engines with a 3yr warranty and they will stand behind them.
I appreciate the adviceI started using Prestige in 2016 on all my builds, I use Smeding now that's all I will say.
