nebraskaairboater
I have a Direct Drive 472 or 500 caddy (haven't checked the stroke to confirm yet.) I am currently running a 72 x 38 paddle wood prop at between 2500 and 2800 rpm (not for sure the tach is working properly) It sounds like it is turning faster than that and I cruise at 1800 and can stay on plane down to 1400 (on existing tach) I will be purchasing a composite wide blade prop and need advice (opinions) on which one to get. I have been looking at the Whirlwind Stump Puller and the Sensenich Q blade. We have a Q blade on a 455 olds direct but it is a 74 inch and I am limited by the cage to a 72 inch to be comfortable with the clearence. What prop (in everyone's opinion) would work the best for the money on a direct drive application? I'm looking for low end push and quiet. I just want as much help to not be stuck as possible, I don't care how fast I can go. Obviously the Whirlwind is probably the least expensive way to go. Also I am running a 600 cfm edlebrock carb on it. Everything else is stock. have headers with 3" flex pipes. any thing I can do as far as tweaking to get a few more rpm out of it? I'm pretty sure it is a 500 cid. (that is what I bought it as)
Thanks,
Dan
Thanks,
Dan
