huntingjman73
I have an airgator, anyone have a winch mounted to their boats? If so, how? I have a 9000 lb Warn winch that is just sitting idle, thought it might come in handy some day. Any thoughts?
Red Dwarf":3ty43g0h said:Yeah it would be nice sometimes
I think just a good come-a-long or "cable puller" would go a long way in most situations.
Most of us are trying to figure out how to lose 70 or 80 pounds off our boats, not gain it.
That said, there is a product out there (I have this on my winch) called plasma rope. It is a polymer-type braided rope that weighs about 4 pounds per 100 feet. It is rated for use as winch cable and it does not stretch, so if it breaks under tension it will not slingshot. Neat stuff. If you use that, you wouldn't be adding near the weight, as most of the weight of a winch is from the wire rope.
FrogNutz":3slnljev said:I have a 3000 lb. winch (small and light weight) mounted under my front step with a small snatch block that doubles it to 6000 lbs. It was on there when I bought the boat and I haven't used it (knock on wood) but I'm sure it would slide my boat with minimal effort.
Red Dwarf":2l3bsnk6 said:That's why you carry a 20 or 30' tow strap as well.
You should never run your winch cable around a tree or attach the hook back to the cable itself. Always use a nylon tow strap or a "treesaver" (6" nylon strap) to run around the tree/anchor and attach your hook to that, preferably with a clevis
