Ultimately, this statement is a demonstrably true fact without a doubt,kwanjangnihm said:OneBFC said:500lbft/ 400hp turns way way less prop and makes way less thrust than 400lbft/500hp
(provided that the definition of "way way less prop" is admittedly a subjective observation).
OK, I accept your challenge.kwanjangnihm said:According to my AC pocket protected fuzzy math excel calculator the engines have equal power and both exceed waterthunder thrust expectations :salute:
I challenge any CM calculators to prove me wrong!!
:stirpot: :fishing :stirpot: :fishing :stirpot: :fishing :stirpot: :fishing
Remember you asked, I didn't set out to beat up your post. :wink:
There are a couple things to be clarified though, so as not to confuse the natives who are new to our little island. :lol:
No need for any calculator. These calculations are suffering from to way to much pocket fuzz to produce a usable result.
There are TWO fundamental problems with lines 7, 8, and 9 that render the displayed results incorrect and of little value.
The first problem being the definition of "power unit" in lines 7 and 8, and then its use a variable in line 9.
While the underlying presumption of a calculated "power unit" MIGHT be usable/applicable in some equation, some where;
it is NOT usable OR applicable to gear ratio calculations such are displayed above.
This is junk math based on a false presumption, and part of what
perpetuates this debate and people's misunderstanding of the subject.
What needs to be understood as basic truths is that:
1) A gear reduction WILL multiply the delivered torque and
2) A gear reduction WILL NOT multiply the produced horse power.
Hence, the above equation implied on lines 7 and 8 are entirely invalid to produce a variable, or for it to be used in line 9.
The second problem is that the equation on line 9 is completely invalid unto itself (even IF the first variable were to be valid).
There is no equation to take any singular unit of measure (let alone torque) and then produce a thrust number.
Even when given a known amount of Horse Power AND Torque, THE PROP is still responsible for producing THRUST.
Bear in mind that EACH PROP will produce a DIFFERENT thrust curve, which will further vary by the amount of power applied.
Hence, an across the board equation could not be derived except for A SINGLE PROP that might be in question.
Even then, it could only happen if all the thrust variables were known and were plotted using the predetermined HP and Torque.
