Conventional wisdom (and the Fla law mandate) says that it should be on the outside of the transom, on the
starboard side and near the top. If you can't/don't find it there, maybe the hull was cut down and it's now MIA.
X2 ^^ Some of the hull builders would put a second set inside the front bulkhead, usually under the top deck or at the top inside corner of the bulkhead panal.
