octane slows combustion, to slow down detonation. Running higher octane fuel will not improve performance, it will actually in a "perfect world" (perfect timing curve and jetting with low octane/vs/ same engine add high octane fuel) decrease performance. In high performance auto engines they recomend using the lowest octane you can run without detonation. Using avgas will not hurt your engine only your wallet.
What Jim said is true and airboat is a good dyno, if you wanted to try both ways it would be a good test. Just make sure the test conditions are the same, same temp and humidity and water conditions.
Have fun
Tim
