Back to mufflers for a moment
roberti53
After all the forum talk about mufflers,
was there a particular muffler chosen to be the quietest?
Up here in Minnesota, and Wisconsin, they are going to enforce an
86 decibel law next year. (that's what I heard anyway)
That is at 50'.
I have a ZZ4 engine, beltdrive, and an 80" 3blade Water Walker prop.
Someone told me that my mufflers were a little loud and I would like to quiet it down as much as possible. (I have stainless steel Borla mufflers now) :?:
I think your best bet is to switch your belt drive to a 2.3 ratio and go with the super wide 2 blade prop.
Changing your WOT from 2500 to 2100 on the prop blades makes a great difference.
I think you should put a bug in the ear of the legislators to impose the same rule on highway tractors on the interstate! Come on now! :twisted: I think that would get a large enough lobby group out.I would maby put something small in front of the borlas but like Faron is implying, you are going to have to spend another 3 to 5 thousand to meet that rule. I just checked a db site and their tests indicate an electric shaver on your face represents 85 db to your ears. Come on now! :evil: :evil:
How about a 86 db jack hammer! :lol:
Robert, what is really important here is how they intend to look for this 86 db measurement.
Is that on the trailer, and if so, at how many feet ?
Is that on plane, and if so, at how many feet ?
Is that at idle, or at wide open throttle ?
What we discovered at the Quiet Airboat demo that we held here in Florida last May was that most airboats with anything better than open headers usually blow less than 90 db on plane at 50 feet. The problem area (and the one that gets us in the most trouble) is the sound that we make accelerating from idle to plane.
That's where really good mufflers make a difference. Find out for me how you're going to be tested and I'll try to help you.
olf
86dba at 50 feet on plane??? The best we have found so far is a good Flowmaster 4 chamber for 3" and for 4" they only make a 3 chamber muffler. But both give a nice LOW tone which is easier to the ear. If you have plenty of exhaust size for your engine then you can add a sweep 90 off the transom point them down just so the exhaust clears the gunnel gussets and the water runs out but facing towards each other -- This to gunnel's greatly reduce the exhaust sound. Set up your own test use a video camera and a dba meeter if you have one ( Radio Shack around $40.00) Be aware of the back ground -- hills -- trees -- homes --- as the sound bounces of these objects as well as it dose off the water. You will find that you will quiet your boat to a certain point and then nothing seems to help ---- This is because the prop sound is overcoming all other sounds. Our sound test at 50 feet on plane we were right around 90overcoming with a 550hp -- 2.3/1 t01 reduction and a 82" Maximus power shift prop. I have heard a lot of good about the new Q series from Sentich props.
Hey you guys! :lol: It is good to have the two of you back together 8) I would be interested as to finding out how much sound is prop and how much is engine? I guess at the 50 foot it is a blend and depending on environment everything will be different. BUT 85 Db?
Cold, most of the difference that good mufflers make is in acceleration.
I have a pair of Dynomax #17748 mufflers on my boat and yes, they're heavy, and no, they're not particularly sexy, and they're not stainless either ........ but ....... they're the highest flowing, quietest mufflers in the Dynomax inventory.
When I rev up the engine most of everything I'm hearing is prop. That narrows it down for me and the engine isn't being restricted just to be quiet.
olf
Roberti-
Can you find the actual wording of the new law & post a link? Look at your state's government website under laws or statues. If you can't find it that way, call your local house or senate member & ask them to find it for you.
Once we can all see the wording, there are many folks on this site that can offer ideas to keep you running. The key is exactly what, where & how the 86 db is to be measured.
PW
ORDER OF THE STATE OF WISCONSIN NATURAL RESOURCES BOARD CREATING RULES
LE-23-06
Analysis Prepared by Department of Natural Resources
1. Statutes interpreted.
Section 30.62(2)(b), (d)2. and 3., and (h), Stats.
2. Statutory authority.
Section 30.62(2)(d)2. and (h), Stats.
3. Explanation of agency authority to promulgate the proposed rules under the statutory authority.
The department is required to enforce the noise statutes found under s. 30.62(2)(b), Stats., but needs a new testing procedure that will allow officers to test boats, such as airboats, which it currently does not have the ability to do in a safer manner under current testing methods. The proposed rule creates a new noise testing method for testing all noise related to boat operation and which the department is authorized to create under s. 30.62(2)(d)2. and 3., Stats. Under s. 30.62(2)(h), Stats., the department has the authority to exempt certain types of motorboats from the noise level requirements for specific uses and specific areas of operation.
4. Related statute or rule.
Section 30.62(2)(b), Stats., and s. NR 5.125, Wisconsin Administrative Code.
5. Plain language analysis of the proposed rule.
The proposed rule will allow the department to safely test airboats and other similar craft to assure that they do not exceed the maximum noise level allowed for operation. This rule simply modifies the procedures used in conducting the J1970 and J34a tests established in Society of Automotive Engineers (SAE). Department is recommending that when an officer requests a boat operator to conduct a boat noise test under the J1970 shoreline test or the J34a pass-by test method, it will be done at a minimum distance of 100 feet. If the J34a pass-by test is used it will be correlated back to 50 feet requirement of the J34a test by adding 2 dB's to the decibel reading obtained from the test. This rule also creates certain exemptions from the noise level requirements of s. 30.62(2)(b), Stats., to allow the use of boats, such as airboats, hover craft or similar craft used during search and rescue operations and when used by agents of federal, state or municipal governments in the performance of their official duties of enforcement, search and rescue, fire fighting or research programs.
6. Summary of and preliminary comparison with existing or proposed federal regulation
that is intended to address the activities to be regulated by the proposed rule.
There are no existing or proposed federal regulations that create a test specific to testing airboat type craft.
7. Comparison of similar rules in adjacent states (Minnesota, Iowa, Illinois, and Michigan)
Of the four states:
Minnesota: Sound laws do apply to airboats, but they are not aware of anyone enforcing the law against airboat prop noise.
Michigan: Does not measure prop noise, but they do require that airboats stay a distance away from residences and that from 11 PM to 6 AM if operating within 400’ of a residence that they operate at the minimum speed necessary to maintain forward motion.
Iowa: Does not enforce prop noise as their law was not intended for prop noise.
Illinois: Utilizes the J1970 sound test, but they do not clarify whether they test airboats.
8. Summary of the factual data and analytical methodologies that the agency used in
support of the proposed rule and how many related findings support the regulatory
approach chosen for the proposed rule.
Airboats and other air propulsion driven boats are commonly used on shallow rivers and on some lakes within Wisconsin. These boats create movement by either using forced air to push the boat forward or by lifting the boat up with air pressure and then moving it forward with forced air. In looking at the safety concerns when testing these types of craft a method is needed to address the safety concerns of operating these craft at higher rates of speed to test them without creating safety concerns for the public, the boat operator or the testing officer. By using currently approved testing methodology and taking into consideration the safety distances needed, the department believes that the proposed rule will address the needs of the department in testing these boats with a safe and technically sound testing process.
9. Analysis and supporting documentation that the agency used in support of the agency’s
determination of the rules effect on small businesses under s. 227.114, Stats., or that was
used when the agency prepared an economic impact report.
Wisconsin law exempts a commercial or nonrecreational fishing boat, ferry, or other vessel engaged in interstate or international commerce, other than a tugboat from the maximum noise level requirement. We believe that there may be some airboats that are used for commercial trapping which do not involve interstate or international commerce. These boats would most likely be illegal to operate if tested under the proposed rule.
10. Effects on small business, including how the rule will be enforced.
The rule is anticipated to affect airboats that are used for commercial trapping. The noise level test created under this rule order as well as existing noise level maximum limits would apply to such airboats that operate in the waters of this state. It is unlikely that most such airboats will be able to comply with the current maximum noise level limit of 86 decibels established by state statute, regardless of the testing method used. This rule will not affect those that only operate on the frozen waters of the state as there is not statutory authority to apply the sound law to the boats when they are operating solely on the ice.
11. Agency contact person: William Engfer – LE/5, 101 S. Webster St., PO BOX 7921, Madison, WI 53707-7921, Phone: (608) 266-0859, Email: William.engfer@dnr.state.wi.us
SECTION 1. NR 5.125(1)(d) is created to read:
NR 5.125(1)(d) When an officer requests a boat operator to conduct a boat noise test under the J1970 or J34a test method, the test shall be conducted at a minimum of 100 feet from the boat being tested.
SECTION 2. NR 5.125(1)(e) and note are created to read:
NR 5.125(1)(e) When the J34a test is used at a distance of 100 feet, the officer will add 2 decibels (dB) to the test results.
Note: Copies of the Society of Automotive Engineers Recommended Practice Report J34a, J1970 and J2005 entitled “Exterior Sound Level Measurement Procedure for Pleasure Motorboats� may be obtained from the Society of Automotive Engineers, Inc., 400 Commonwealth Drive, Warrendale, Pennsylvania 15096.
SECTION 3. NR 5.125(6) and note are created to read:
NR 5.125(6) Exemptions. Any boat being operated for one of the following purposes is exempt from the noise level requirements established for motorboats under s. 30.62(2)(b), Stats.
(a) A boat being used by an authorized agent of the federal, state or municipal government to carry out his or her official duty of enforcement, search and rescue, fire fighting or research programs.
(b) A boat being used for search and rescue or training for search and rescue operations at the request of a governmental agency, while being used under the direction or control of a governmental agency.
Note: Section 30.62(2)(b), Stats., states that no person may operate a motorboat powered by an engine on the waters of this state in such a manner as to exceed a noise level of 86 measured on an "A" weighted decibel scale.
SECTION 4. Effective date. This rule shall take effect on the first day of the month following publication in the Wisconsin Administrative register as provided in s. 227.22(2)(intro.), Stats.
SECTION 5. Board adoption. The foregoing rule was approved and adopted by the State of Wisconsin Natural Resources Board on ________________________________.
Dated at Madison, Wisconsin ______________________________________
STATE OF WISCONSIN
DEPARTMENT OF NATURAL RESOURCES
By ____________________________________
Scott Hassett, Secretary
(SEAL)
Robert,
It is unlikely that most such airboats will be able to comply with the current maximun noise level limit of 86 decibels established by state statue, regardless of the testing method used.
I wouldn't like the statement above as well as them using noise instead of sound for verbage.
We did learn a lot this past May at the Sound Demonstration. I started with a 2 bl prop, now with a CR running Sensenich. My prop sound signature dropped drastically with a CR assembly but yet I now have an exhaust signature to work on quieting.
14 X 8 454/425 HP CR with stainless Airboat Pros mufflers.
Basketcase
The level they are seeking can be met by airboats but it will cost a considerable amount of money to do it and most aircraft engines are not gonna make it.
It will take a very good set of mufflers, a slow tuurning prop designed to provide thrust while turning slow.
It can be done but most are not willing to do it. adding back 2db for a test at 100' on plane is very generous on their part.
