Bargain located on complete soap sprayer system
Daddy Dave
Fellow airboaters & firefighters BHayves and Harry T. have located a real bargain that can help a whole bunch of us that suffer with the summertime stickies.
Seems Harbor Freight Tool Co. is advertising a slick self contained ABS 15 gallon sprayer tank with 15' of hose and 12 volt pump installed for $99.95. All you have to do is add hull sprayer tips. Mine is on order.
BigDaddy, I bought one of thoughs setups Friday. Used it yesterday while busting roads in the mash here in Louisiana and it worked great.
Kevin
Bigdaddy,
I actually did my senior design project on this and drilled a small piece of stainless tube. Ran one line out of the bow and T'd into that. Designed it to spray on the hull. The game department guys use the sprinkler heads flush mounded in the bottom of the bow for there egg collections. These spray the ground. I have some pictures of that from one of those guys somewhere. Have a whole power point presentation on the other but I do have to say the flush mounted sprinkler heads hide better and looks a little neater. However if you got real creative you could probably incorporate into the grass rake or something of that nature.
BigDaddy,
In these parts we use agriculture spayer tips. they are used on the booms of tractors to spay crops. I have two on the front of my hull and the fan out past the sides of my boat.
I will see it i can find them on the web for you.
Kevin
Kevin,
Thank You. Am awaiting the sprayer's arrival at the Harbor Freight down the street. Will get the tips you suggest. I was considering 75 degree Rain Bird pop ups.
