Hi. I am new to the airboat scene and here in northern michigan airboats are pretty rare, anyways we picked up an old tour boat down in florida for hunting and generally running around the swamp.
so far we have got it stuck a few times, it will almost make it accross the marsh grass but not quite, the last time our jet outboard johnboat was able to easily pull it off with the airbout throttled up. so I am hoping one of you guys can give us some advice on what prop or other means we can use to give it a little more get up and go power. we dont need to run dry ground, really we just need to cross semi flooded marshgrass/cranberry bog areas to get from the river to the highground.
the boat is a 16 foot aluminum, no polymer, with a 500 caddy and a wood prop mounted direct on the crank. hope you guys dont mind helping a yankee, but there just isnt anyone to ask around here so we decided to ask the experts.
