first of all, always go with a rake. you never know where you may have to run. pull your gators over from the side. here's a trick, cut a piece of 3" PVC pipe about 2 feet long. cut them lengthwise and put them over the sides of your boat. makes it a lot easier to pull gators in when you're by yourself. i personally wouldn't go with a deckover because gators tend to come back to life when you get on the gas. would suck to have to tie each one up before you go to the next line. i wouldn't get jump seats, unless you get bolted on ones that can be taken out. i really don't think the length of the boat matters as long as its at least 13 ft long. i've loaded 7or 8 gators in a 13 X 7 and they averaged 8 ft long. you can just about tie them into a knot in order to cram them in there. anyways, you don't want to keep the gators in the sun too long, so by the time you catch 7 or 8 its time to take them to a wet shaded spot so that really dismisses the NEED for a 16 ft boat. its not like you're gonna drive around all day with a dozen gators in your boat. always keep a wet sheet over your gators to keep the hide from slipping, but you probably already know that. thats just my opinion
