Blade size
DukHntr239
So I need to order new Saber blades, no hub, just the blades.
How do I know what size to tell them I need?
Are all the blades all the same sizes, and it’s just the hub size that makes them bigger?
So when you’re ordering a 70” prop from them, does that mean it’s coming with a certain size hub as well?
Or do I need to actually take the blades out of my hub, and measure them in order to tell them what size replacement blades I need??
Thanks for your help guys.
All Saber blades are 33" long and in a standard hub that measures 12 inches in diameter you get a 72" prop. So for a 70" configuration, the blades will need to be trimmed down 1 inch. If you need further assistance, you can give me a call or send an email my way.
Hope this helps..
Hope this helps..
Thanks for your reply and help.
My blades measure 35” from tip to center of hub. So that means I have a 70” configuration right?
I’m not near my boat so I can’t measure the diameter of the hub right now. But I’m guessing I either have a small
Hub or the previous guy had the blades trimmed.
Is there a reason or benefit to having the blades trimmed 1” shorter?
