Blades & Hub
Whitebear
Silent Prop
R. I. P.
Got a kid that moved back to FL and is putting together another airboat. He has Whirlwind Whisper Tip 2.0 Blades for a 76" pop. The question is will these blades fit a Water Walker HUB????? What say you ??
I have done it before. fit fine.
:stirpot:
Took 4 of the WT2.0 blades to produce similar thrust as 3 Max blades at the same diameter for each.
Anyway, they will indeed fit in a Water Walker hub since he has the blades already.
Hope that helps!
I don't know what I was drinking when I posted that last response. I need to correct myself.
The Whirl wind blades won't fit in a Water Walker hub...
so sorry for any confusion. I totally forgot we swapped hubs and all the day we tested on mine.
Apologies!
Bear, I'm surprised this is a question but oneBFC is correct "in his final post"
Normally the prop is the last addition but you know things can be built backwards!
Is this for an Oldz 455 dd build?
No, its for a pal that has a boat together and found these two parts separately, hence the question. I couldn't be of much help, if he was asking me about wood props I could talk for days LOL
I can relate to woodies for a cad or a lyc 125, but those days are way past and should stay that way.
Not the first BBQ I've attended with leading edges poking out of the grill!
