boat for sale
cntry141iq
Silent Prop
R. I. P.
My boat is for sale. i will put it in the classified section on here. If the buyer mentions SA as where they saw it I will donate 500 bucks to the club/site.
2004, 14' X 7'6" ALUMITECH SLIDER HULL, 20" HULL SIDES, 2' ALUMINUM GRASS RAKE, POLYMER BOTTOM AND SIDE STRIP, STAINLESS STEEL RIGGING, NEW STAINLESS STEEL STEERING CABLE, 2 TWO MAN SEATS, BUILT IN COOLER RACK UNDER SEATS, 80" WHIRLWIND 4 BLADE MASTER BLASTER PROP, 40 GALLON GAS TANK, NEW ALUMINUM AIRFOIL RUDDERS, FROG CHUTE, LARGE FRONT DECK WITH HATCH AND NON-SKID, DUAL BILGE PUMPS.
383 CHEVY STROKER, 456 HP/456 TQ,. 4-7 CYL. SWAP CAM, HYD. ROLLER ROCKERS AND LIFTERS, CANFIELD ALUMINUM HEADS FULLY CNC PORTED, NEW ALUMINUM WATER PUMP, ALUMINUM AIRGAP MANIFOLD, HOLLEY 750 D/P, NEW ALUMINUM RADIATOR ,DIGITAL 6AL MSD IGNITION BOX, MSD LOCKED OUT DISTRIBUTOR, HIGH VIBRATION MSD COIL, NEW MSD WIRES, k&N AIR FILTER, DUAL BREATHERS ON ALUMINUM VALVE COVERS, MARCH ALTERNATOR BRACKET, 1 WIRE ALTERNATOR, NEW BELTS, SEPARATE BELT FOR WATER PUMP ONLY, TWO NEW RED OPTIMA GEL BATTERIES, SUPER QUIET EXHAUST SYSTEM WITH X-PIPE, THRU HULL DUMPS, NO FLEX PIPE, STINGER GEAR BOX 2.09, 80 HRS ON NEW MOTOR.
2004 B&S SPORTSMAN ALUMINUM TRAILER SINGLE AXLE, LED TAILLIGHTS, PLASTIC COVERED BUNKS, REAR ROLLERS, NEW WINCH STRAP, ALMOST NEW TIRES, THE BOAT LOADS DRY EASILY WHILE FULLY LOADED.
THIS BOAT RUNS VERY FREE IN THE WATER AND RUNS DRY GROUND AND HILLS WITH MORE PEOPLE ON IT THAN IT SEATS. THIS IS NOT A BEGINNER BOAT. HAVE GPS'ED IT AT 69.8 MPH. BUT IS VERY STABLE FOR AN EXPERIENCED OPERATOR BUT IT IS A SLIDER HULL. BOUGHT A NEW ALUMITECH SLIDER HULL SO SELLING THIS ONE.
19,500.00, JOHN O'NEILL NEXTEL 161*192121*16, 941-345-5726
