I took the boat out again today after replacing the rubber motor mounts. It will run dry in my back yard on the grass but if I hit a little dirt it stops.
The boat is still porpoising really bad. I had a friend of mine drive it and he said it's not riding on the nose it's porpoising. I play with the trim tab but it was still doing it. It has to be adjusted by hand so I can't move it on the go.
would putting a jack or 2 in the bottom help it. I would really like to get it to stop porpoising with out the trim tab. When I have it down it does not run dry to good.
thanks for all the help
