Mike Thurman
I recently serviced a couple boats for a state agency I take care of. Both boats have 6 cylinder angle valve Lycomings. They both had Denso Plugs. On the first boat I had one Sparkplug break off. On the second boat I had 4 break off. All on the top plugs. The angle valve cylinders have a little pocket that will hold water around the plug. Denso plugs are not plated like the Champions which allow them to rust up faster. You can also see the small amount of metal on the plug for the socket to grab as compared to the Champion plugs. I thought I learned on the first boat so I ran the motor and got the cylinders hot and used all the PB Blaster type stuff for rusted threads. Talk about a chore to get these plugs out. It took a couple hours to get them out,but I got them.
