ASC539521 Piston can be used to bump compression and horsepower
ASC539521
Order 12 or more Pistons and Save 10% Only applies to pistons - you can mix part numbers - Discount is automatically applied at check out. ASC539521 Piston C-75, C-85, C-90, O-200 & O-300 Continental Series Engines 9.5:1 Compression Ratio in C-90, O-200 & O-300 Series Engines 8.4:1 Compression...
combustech.com
I am am an A&P IA and build experimental aircraft engines
I also have a 337 for putting C-85 0-200 jugs on A-65 cases but you dont need it for airboats
Divco cuts the bore for the jugs
so long from Baldy in No az went to high school in Venice Fla class of 65
