472/500 heads are the same. You need to know the casting # so someone can let you know if they have a set that will work as there are large and small combustion chamber options. Last 3 #'s are needed. Remove valve cover and check.
Getting the wrong heads will make the engine either pitiful or in pieces. I'm sure someone here has what you need.
